An app to open downloaded file. (1 Viewer)
The Dotties
1,872
4,022
Gloucester
In between
Ex Newbie
I have a Acer laptop, which I admit I don’t understand very well. It’s on W10.
It became slower and slower till it eventually threw the towel and refused to be owned by a numpty!
I took it along to a very nice man that owns a computer shop that advertises as a numpty put right man. They do have a good reputation.
It transpires that the laptop was so badly corrupted that it refused to work any more, so he saved the bits I wanted to keep, photos and music mainly, then removed W10 completely.
It was then reinstalled, again with W10 and returned as a brand new machine. (The lap top itself is immaculate, just the software was corrupted)
My problem now is that I need to update the sat-nav in my Smartie due to the imminent update to the WNRO code which involves downloading a file from Tom Tom.
I’ve successfully :LOL::LOL: downloaded the file but Acrobate won’t open it so it can be transferred to a USB stick.
Any ideas anybody? If possible keep your suggestions to one syllable, or preferably one letter.
Your computer king
Geoff
Brucek
64
65
Can't you just drag and drop the file onto your memory stick without opening it?
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
Since 2010
The file will consist of a filename and suffix. An example would be 'filename.pdf' it is the suffix .pdf which determines what program the file needs to open it. The program may not be on your computer and you can install it.
Wyn
Kannon Fodda
2,578
7,977
Seek and Ye May Find
Autotrail V-line 540
I Make Schoolboy Errors!
By default the suffix (.pdf , .doc etc) is hidden. If you right click on the file you'll be able to see the suffix and a google may then tell you which program can open the file.
Sometimes windows expects certain files to be opened by a particular program. It may want to try and open pdf files through the all encompassing edge browser thing. But that can be a problem. Again right click and you should get a menu allowing you other "open with" options.
My recollection of most sat nav update things is that, at Brucek suggests, you copy the file to a USB stick rather than open it, place stick in the van's socket and then run the update option on the sat nav.
But there should be some sort of instruction set on both the tom tom site and that came with your sat nav?
The Dotties
The Dotties
1,872
4,022
Gloucester
In between
Ex Newbie
The file name appears to be TomTom.000
Acrobat says it is unable to open it.
The Dotties
The Dotties
1,872
4,022
Gloucester
In between
Ex Newbie
I’ve just tried @Brucek suggestion. It appears to be downloading now. I’m off to put it in the car!!!
Many thanks to you all
Brucek
64
65
To drag and drop it, assuming you are using a touchpad 'virtual mouse'
Plug in your memory stick
Open Windows explorer (using the Windows menu bottom left of your screen)
The memory stick should show up as a 'drive' in explorer maybe e: or f:
Find your tomtom file and move the arrow over it using your touchpad
Click the left touchpad button and hold it down
Using the touchpad you should be able to drag it to your memory stick
Then let go the left button to drop it onto your memory stick.
Once you do this you should be able to plug the memory stick into the satnav which should be able to read it
Edit:
Sorry just read your post, didn't mean to treat you like the beginner you obviously are not!
The Dotties
The Dotties
1,872
4,022
Gloucester
In between
Ex Newbie
Brucek,
Beginner! I should wish I was that qualified:D.
Thanks for your help, now succeeded. I’ve been four days trying to do this!
Thanks to all of you for your help
