Jim
Ringleader
An Ampere Hour (Ah) is a way of measuring how much electricity a battery can store and provide over time. It’s especially important for motorhomers using leisure batteries because it helps you understand how long your battery will last before needing a recharge.
Breaking it Down Simply:
- 1 Ampere (A) is the amount of electrical current flowing.
- 1 Hour is the time it flows for.
- Ampere Hour (Ah) is a combination of the two.
- A 100Ah battery can, in theory, supply 100 Amps for 1 hour or 10 Amps for 10 hours or 5 Amps for 20 hours before it runs out (though real-world conditions affect this).
Why It Matters for Motorhomers:
- Estimating Power Use – If you have a device that uses 5 Amps (e.g., a 12V TV), a 100Ah battery could power it for roughly 20 hours before running out.
- Understanding Battery Limits – Many leisure batteries shouldn’t be fully drained. A lead-acid battery should ideally not go below 50%, meaning a 100Ah battery really only gives you 50Ah of usable power. A LiFePO4 battery can be discharged much further.
- Choosing the Right Size Battery – If you run a fridge (5A), lights (2A), and a heater fan (3A), using 10A per hour, a 100Ah battery will last around 5 hours before hitting 50% capacity.
Key Takeaways:
- Bigger Ah = More stored energy = Longer running time.
- Usable Ah depends on battery type (lead-acid vs lithium).
- Know what you use to avoid running out of power!
