Am I in the right ballpark with these calculations?
Tropical Skelmorlie
Globecar 5.4 Shine
Since 2013
We have 420Ah of battery, a 1500 watt air fryer and a 2000 watt inverter. Running the fryer for 20 mins reduced the battery by 5%.
I'm interested to see how the figures stack up.
So 🤔 running the fryer for an hour would equal 1500Wh, so for 20 min that's 500Wh.
To convert to Ah, we divide by volts, (12?) to give 42 Ah, which is 10% of the battery, not 5%.
I realise that the fryer would turn itself on and off during the 20 mins, but it would only have to be on half the time. And then there is the inefficiency of the inverter to take into account. 😐
So I wonder if someone could tell me if I'm in the right ballpark with these all of this? Or way out 😕
Using 90% inverter efficiency, and 12.8v nominal from your battery I get 10.2%, so I presume the fryer is cycling as you say.
What gives you the 5% figure, and what type of battery?
2 x 210 lithium, and the 5% from it's associated app.
OK may not be 100% accurate, but shouldn't be far off, so the air fryer must be cycling - which is good news!
Can the app show any history or realtime amp draw - would be interesting to watch it once it has warmed up....
Yes. I'll investigate next time we use it. And thanks for your comments.
What charging method do you use, if your plugged in or have a fair amount of solar that will replenish some amps while the fryer is used…
so youve took 20ah from the batts, decent going that, 240wh. the inverter wont have even used an amp
so you could cook chips for all the camp..winner
Do you not trust the app, or just a general check
are they fogstar batteries /app
How can you discover which version of the app you are running. Can't find anything to indicate on my iPhone 8
I use Android, so it's going to be different. The app is XiaoXiangElectric (Little Elephant Electric) and bottom right on the main screen is an icon Mine which gives the info. The app isn't particularly well reviewed, but it works on for me.
Air fryers do cycle on & off once up to temperature. Only the fan stays on all the time. I was surprised to see how much time they spent with the heating element off, so your estimate of actual consumption being around half the rated power sounds feasible.
Thanks. Yes, that was my conclusion.
As soon as we turn our inverter on we draw quite a few Amps even without a load on it, I am not overly technical but think you may have over simplified the maths
It shouldn't take that much in standby David as long as there is nothing else connected, I know ours doesn't.
Our Multiplus II 3000/120 spec is in watts:
We mostly only switch it on when needed so 13w, but have tried search mode which is only 3w
A lot depends on the make of inverter I guess.....
