Came across this today £9.99 in the special buys. Build quality looks great
Yes a bit lower than our step but on level ground it's a better height for our vanWe bought one last time round. It was a solid substantial piece of kit but a little low for our set up. It still left a big climb to the van.
We used those as side tables when sitting in the sun, we have this size and a taller one. The smaller one turned upside down is useful when using a collapsible bucket as it holds it up so it can't flop down if you catch the side ... I've had the 'soggy feet' t-shirt a few times!What about this one? 100kg maximum and very cheap!
https://groceries.asda.com/product/...6795&cjevent=7db453f9106c11f0830700600a18b8fb
Mmmmmh! How can a thread about a folding step deteriorate into a wet t-shirt contest?We used those as side tables when sitting in the sun, we have this size and a taller one. The smaller one turned upside down is useful when using a collapsible bucket as it holds it up so it can't flop down if you catch the side ... I've had the 'soggy feet' t-shirt a few times!![]()
Bought 2 of those about 10 years ago. They both lasted about 3 months and the plastic splits. The second one was from Spain and was labelled "Robusto" was it hellWhat about this one? 100kg maximum and very cheap!
We've had ours for years, the key is to ensure you use them correctly and ensure they are fully extended, many seem not to make sure they 'lock' into place so the tops are raised up on the side lugs thus they break.Bought 2 of those about 10 years ago. They both lasted about 3 months and the plastic splits. The second one was from Spain and was labelled "Robusto" was it hell![]()
