Hi folks,
Quick question if you don't mind? I've got a 2018 Swift Bessacarr e599 and I've fully drained the water, taps open, etc. There's a wee bit of frost on the windscreen tonight, so I've decided to put the heating on to 10 degrees Centigrade in the motorhome, as someone has planted a seed in my mind about the residual water in the water pump potentially freezing and cracking the pump. Having fell foul of pipework freezing in the campervan last year and having to replace the kitchen tap and water pump, I'm a bit paranoid of it happening in the motorhome.
My question I've got is; Will I damage my heating system by not having any water in the tanks? I've turned the water heat function off and got it on 2kw at 10 degrees running off gas. I'm sure I read on here recently that even with the water heat function turned off, it'll still warm the water. It was just a passing thought and I thought I'd run it by those more experienced than myself.
Thanks in advance.
Arron.
Thanks in advance.
Arron.
