alde 3030 overflow leaking from bottom
Tiverton, UK
rapido i1090
since 1996
hi we have a leak from under my boiler, it is only 7 months old.
any suggestions on how to stop it please
Pictures of leak would help with suggestions to fix
hi,
the leak is from the boiler it is a safety thing
it seems the boiler is getting hotter that it should, the water is very hot i am hoping to find a way of lowering the temp of the water
You said it is from boiler n opening thread but exactly where is the issue.
As nobody knows that will be why there’s no replies.
Good luck changing the temp of boiler, if it is over temp then there’s probably more wrong that a road side repair can fix.
Or contact Alde Tech they are good and will reply quickly I'm sure
