If the sensor battery fails does the switch fail in the open or closed position?
When the battery dies on the wireless contacts on our AutoWatch alarm the contact can no longer transmit a signal if the magnet moves away from the contact sensor, so the alarm does not get triggered.If the sensor battery fails does the switch fail in the open or closed position?
Mine did, I fitted Duracell batteries and the alarm kept going off some of the new batteries were down at 2.9v. Fitted new chepo batteries, never gone wrong since.When the battery dies on the wireless contacts on our AutoWatch alarm the contact can no longer transmit a signal if the magnet moves away from the contact sensor, so the alarm does not get triggered.
Ours take the theory route as I opened lockers before now having forgotten to unset the alarm which then indicated that the battery in the sensor had died.Mine did, I fitted Duracell batteries and the alarm kept going off some of the new batteries were down at 2.9v. Fitted new chepo batteries, never gone wrong since.
I agree with your theory but doesn't seem to work in practice.
Been using some branded "100% Peak Power" from Amazon they have been really good about a fiver for 20, bought originally for some Christmas lights and found them really good so bought some for the van and they have not let me down.CR2032 cells for the most part are crap and the only ones I have found to be any good are made by Toshiba, but they are not easy to find.
I think it is just an indication that the sensor is working.I have a Moving Intelligence alarm system with wireless sensors. There is a red LED on the sensor. Can anyone tell me what the LED is supposed to do and what it signifies.
Does it flash or is it permanently lit?I think it is just an indication that the sensor is working.
I was told that if it goes dim (or doesn't light up) the internal battery is flat.
I change my batteries once per year as a precaution.
It only comes on for one or two seconds when the door is opened. It is off at all other times.Does it flash or is it permanently lit?
Great thanks. That's what I was needing to know.It only comes on for one or two seconds when the door is opened. It is off at all other times.
