Airfryer (66 Viewers)
Aug 13, 2024
21
37
CI Auto Roller
Hello..would I be able to use my airfryer pikkies included..in FREEDOM my MH.only on EHU...that's all Im using...dont want to take it and try and turn on and I go and blow everything...thank you for all help...
tonka
11,051
22,198
Cannock, Staffs
A class Burstner 800
Since 2000
Only if your on a EHU and have a minimum 10 amp supply..
Basic way to work out is 2000w (as shown on appliance) divide by mains voltage 230v (average). = 8.7 amps..
So you would need to check site supply and also ensure your not running any other large items if your limited to 10 amps.
Some sites will give 16 amps and some limit it to as low as 6 amps..
We carry a small 1000w airfyer, ideal on 6 amp supply and we can also use it off the van battery with an inverter.
W
Aug 13, 2024
21
37
CI Auto Roller
Thank you for once again all who came to my aid in helping me in these matters...now just have to figure out what pipes to keep open and what to shut in my mh to get her through winter..so no frozen disasters..crumbs what alot of things to remember...hopefully will have a few more weekends away for a while yet..fingers crossed. 🤞
Nanniemate
6,827
46,997
IH
Where are you a friendly funster my offer to come round to help
empty every tap pipe valve and blow water out back.own taps to make sure none in pipes
33,600
69,925
... also the toilet flush too but I'd resist 'blowing' the water out! :giggle:
Sep 3, 2012
8,051
27,484
Cheshire
C Class Elddis 175
8+ years
We bought a 1000w airfryer from Asda. ÂŁ20.
it's only a small capacity unit but does the job.worked well on a 6 amp supply but not yet tried it through my inverter which was the ultimate plan
Feb 12, 2018
857
5,700
South Yorkshire
Adria Coral 600SL
Since 2017
We recently bought the same model, mainly because of the compact size for stowing and the low wattage rating (which I think is actually 900 watts). Thought it worth a punt at only ÂŁ20. Has proved to be a very useful bargain and SWMBO is delighted (although when I brought it home she made a remark about another off my daft ideas).
Of course the capacity is small and it is only suitable for a couple of people. Frozen chips, fish, even fresh veg coated in a little oil before cooking, all have worked well. However, given the low wattage it does seem to take a little longer than our more powerful Air Fryer at home.
No problem when on EHU obviously, unless you have the Truma on electric heating and inadvertently turn on the electric kettle at the same time, which trips the external supply. Have tried on our 1800 watt inverter and again no problems, but you have to be aware that it consumes around 40 Ah (of our current max 210 AH lithium set-up) if used for cooking something which takes 30 minutes.
We are happy with this very budget-priced and smart looking compact product, which meets our needs. However, if you are reliant on extensive use for cooking meals you probably need to have the capacity and options to re-charge which Lenny HB has installed in his new Carthago MoHo.
56,380
166,840
That's seems high I don't think you have allowed for the cycling the heater is on for less than 50% of the time.
I happened to check what we used last night cooking a frozen Cannelloni in our 1400 watt airfryer it was on for about 50min, used 40ah. We have 485ah of Lithium.
33,600
69,925
We have 2 air fryers ... :rolleyes: ... hubby got a like new one off a local charity (via Ebay) for ÂŁ7.50 as he just wanted to see how he got on without splashing a load of dosh, he was surprised how good it was but admittedly it was a bit small for some things so he then got a 7L Tower Vortex one off Ebay for ÂŁ26.99 (Argos return - unused), and he loves it. He had looked at twin drawer ones but again you've still got the issue of them being too small for some stuff although you can get some with a removable divider with a large single drawer but they ain't cheap! Consequently we have 2 'black eggs' in the kitchen but are fortunate in having sufficient work surface so they aren't a problem.
What I'm trying to say is that you may find getting a smaller one is more convenient to take away as I think the below is yours so it's quite a beast:
Apr 11, 2015
5,841
60,461
hull
Laika Ecovip 300
We bought a lower wattage air fryer from Dunelm just for the van. Has been well used this trip lamb chops last night were lovely. Rarely add oil my beloved remoska on the other hand hasn’t been used so much. It is a newer one and lower wattage than the old one which I still have think I will be swapping them over
Apr 27, 2016
7,451
8,916
Manchester
A class Hymer
Since the 80s
As tonka says,
Next question, how do you know what the supply rating of the hookup post is? Usually you can see the trip switches, and the amps rating will be written on it. With a B or a C in front of it. So if it says B10, B13 or B16, or C10, C13 or C16, then it should be OK. If it says B6 or C6 then it will probably trip.
This one for example has C13 written on it, so is good for 13 amps. That's the switch on the right.
Ignore the one on the left, if it has a test button and doesn't have a B or C amps rating, it's for electric shock protection, not for tripping due to excessive amps.
Oct 28, 2016
23
34
East Sussex
7 years
We always take with us our Dual zone Ninja Air Fryer. 3kw. It works fine, providing you remember not to turn on other high power items. I'm a senior citizen and constantly forget. It's so easy to turn the kettle on !! I'm frequently tripping the mcb's. Irritating but not the end of the world.
Emmit
8,385
18,906
Pilote Explorateur
Jan.2014
For those who go Sur la Continent, it would be wise to buy an appliance rated at 1200 watts.
Then it could be used on the many sites that have 6 amps.
And, providing you don't rip the backside out of it, it could be used with an inverter rated at 1500 watts. But not for a long cooking time. It would use 100 amps+in an hour.
56,380
166,840
You have a lot of battery power then?
