Airbag suspension.
Bridlington
Swift Sundance
5 years and still learning
Good evening Funsters. I'm thinking about fitting airbag suspension to my MoHoI.I have a 2005 Swift Sundance 630L and drag a toad,any advice and/or recommendations would appreciated. Many thanks in advance for all replies.
Sorry don't know what your rear suspension is on that motorhome. Best place to start is a search on here for rear suspension.
That should enable you to narrow down which type of system u require.
I would say its standard fiat leaf spring so just the normal air assist kit
A lot of 630L and 630G models of that era had the dealer upgrade to 3850kg with airbags fitted from new.
My 2003 630G is at 4000kg now but obviously you would have to watch your towing capacity if you upgrade
Or do you mean full air suspension ?
Hi busbuddy. Just wanted to know if it would be a less bumpier ride.
I've got the VB semi air on the rear axle.
Yes. It makes my bus much more stable cornering and overtaking/being overtaken.
I've just got the air assist bags on the back of mine, they help a lot with swaying and bumps.....they take a bit of experimenting to get the pressure just right (it's an individual thing)but I only use 2 pressure settings now...one for fully loaded to the max and one for quick light load weekends away
