- Jul 19, 2022
- 208
- 158
- 2015 HymerExsis i414
- 20+ years in 1990 VW T3 and Florida. Hymer now...
Hello All, I really need your help!
2015 3.0 euro V (I believe as that's the fusebox I can see)
I've got an airbag error, but not the usual ones. Mine is B0143-64 Plausibility error.
In MAR the airbag lights, does its self checks and then goes out. About 4 ish seconds later, there is a beep and the airbag light comes on, with a message to check the passenger airbag.
Using MES, I read the B0143-64 error code.
Using eLearn, DTC I have the following checks
Using MES I can operate the airbag light on the dashboard, so moved on to check number 2.
I disconnected the Hab and starter batteries (after following procedures to allow for dissipation etc) and disconnected the airbag ECU connectors.
Below is the wiring diagram
I thought that the best place to start was the CAN lines (pins 7 and 8 of Connector A)
The wire colours for these CAN wires does not tally with the diagram above. Mine are white and blue. All others on Connector A do.
There is also a wire from pin 9 but this is not shown in the wiring diagram
Have I got the correct diagram?
I'm a complete novice with this depth of Electrickery and your help would be gratefully received to be able to sort out this fault.
