As anyone got semi air suspension on the rear of their motorhome if so what do you set your bar pressure at for a good ride. Thank you.
That’s true and I found out that if I put too much in then it made the ride harder so I would say start at the minimum which on mine is 0.7 bar and work up until it feels okay.There is no normal pressure. You should experiment until you find the one that suits you and your vehicle.
Geoff
