Air Suspension
tuscancouple
Kent
None
Our Ducato PVC sit's low at the back even though it's weight is 300kg less than max which is 3500kg . It came from the converter this way as it appears too much "stuff" was placed towards the rear. Nothing actually wrong, but springs were down on bump stops, so not the most comforatble. Also didn't look level and my internal spirt level couldn't cope :)
Had VB Air Suspension fitted today by Rosmia in Bolney, Sussex. They did a great job in half a day and now the camper sit's perfectly. So a big thumbs up for Rosmia.(y)
By the way I know I could of fitted them myself, but it's cold outside :)
Mick
derbys
AUTOSLEEPER SYMBOL
My van is the opposite,,rear end sits 4 to 6 inches higher than the front,,Usually have to use levelling blocks to even it up on site. Its a bloody nuisance..BUSBY.
Europe
€6 Peugeot Boxer van conv
50 years inc camping and caravanning (and I'm not much older than that)
This is something that I'm interested in, and might fit - when it's warmer. From what you wrote, it appears to have been worthwhile.
Questions, questions!
Did you have a compressor fitted or schrader inflation points?
If it's schrader inflation points, where are they located? (they're often fitted in the drivers side cab step)
Can you adjust both sides independently, if so, can you adjust the side-to-side level of your rear end?
What's the ride like, any softer? I believe that it's dependent on the pressure, and that ~1 bar is normally good.
Have you got any idea what they weigh? (or reduce your payload by?)
Ducatos (and all x290's) are designed to run on the bump-stops (in fact they are spring assisters), in case anybody else is reading this (but they do make the ride bumpy).
tuscancouple
tuscancouple
Kent
None
So to answer your questions:
Schrader inflation points, although semi auto or full auto compressor fill is an option.
Yes although pressure difference must not be >0.5 bar
Ride feels smoother, less harsh bumps. The amount of pressure is dependant on weight of the PVC and required ride height, more weight or ride height = more pressure.
About the same as the bump stops they replace. They have no effect on the PVC payload at all.
You're correct with the bump stop use, however it does make for a very firm ride and I guess converters don't use a heavy duty springs (extra leaf) as it would reduce payload.
Hope that all helps.
Mick
tuscancouple
tuscancouple
Kent
None
Missed one :)
Had them located behind rear wheels on the lower still. They can be put anywhere you wish, within reason though I didn't want them in the PVC.
Mick
soreeyes
Sunlight T69L 2017
im a newbie
Springs down on bump stops ?
Have you checked the rear axle weight as you can exceed a axle weight without exceeding a gvw.
Steve494
Nottinghamshire
Bessacarr E530
Since 2008
Anyone reading this thread with a coach built MH, another added bonus of air suspension is that you DRASTICALLY reduce ‘roll’ when going around roundabouts and bends and another surprise to me was the reduction of ‘roll’ when being overtaken by lorries. (Not that lorries overtake me very often!)
Wem Shropshire
Carthago E Line 51QB
Been getting away since 2008
Thinking of fitting this on my Alko chassis to uprate the gvw.
Steve494
Nottinghamshire
Bessacarr E530
Since 2008
Hi Rob,
That’s the reason I had it done in the first place.
We wanted to carry a scooter on the back. We had to change the rear tyres too.
The unexpected advantages from air suspension was a nice bonus.
Also, on the Scottish small ferries, we were able to raise the back end a good few inches to stop the MH from ‘bottoming’ out.
Wem Shropshire
Hi Rob,
That’s great thanks, where was yours done and how much could you raise the back end by, you say a few inches?
What van/chassis have you got?
Rob
Salisbury
Hymer B678DL A class
since 2011
Rob
It’s a bit more expensive on an Alko and most suppliers will not sell them for diy.(y)(y)(y)
MisterB
Essex
Adria 670 SLT
Mick
cost???
North Wales
A class Carthago Chic I47
34 years
Mick
A S AirSuspension Nr Warrington
Wem Shropshire
Was looking at AS in Warrington as it’s only an hour away.
I know it’ll be expensive, probably a couple of grand but it’s nothing in the big scheme of things :frowny:
Steve494
Nottinghamshire
Bessacarr E530
Since 2008
Hi Rob,
I’m going senile in my old age so I’m not 100% sure on some of the details.
Our MH is a Bessacarr E530 on a Fiat Ducato.
It’s a 2007, not sure on the running gear but I’m sure you could google it.
I bought the diy kit and got my local garage who services the MH to fit it.
I think the kit was a Dunlop kit and I think it was about £400?
The garage had never done one before so it took them longer to fit than a ‘regular’ fitter but I’m sure the fitting was only about the same as the diy kit. One lesson they did share with me was to leave small amounts of slack in the air pipes as the chassis obviously ‘moves’ when driving and the pipes can kink easily.
We uprated our MH from 3500 to 3850 if I remember correctly which was perfect for the scooter weight.
The two obvious disadvantages of uprating your MH weight are that you will have to take a further test when you hit 70 and the disadvantage that I hadn’t planned on was that there are a lot of roads particularly in France that have a 3.5t limit on. So technically you can’t use these roads, however police seem to turn a blind eye to MH’s in France.
Interestingly (if you’re still awake) when I was doing the paperwork for the weight uprate I may have forgotten to send the original V5 back to DVLA, and I may have forgotten to take it out of the MH. Which means I now run with two V5’s, one showing the MH as 3.5t and one which shows it as 3.85t. So if I get pulled for being down a restricted 3.5t road, I may forgetfully produce the wrong V5!
Wem Shropshire
Hi Rob,
Thank you very much for that and I like the idea of the two V5s, might forget to send mine back!
