Is that why the other one has more replies?I don’t know why there are two of these threads…. This is the main one..
Air suspension pressure..
I have air suspension on the back of a fiat ducato pvc what should the pressure be roughly please…www.motorhomefun.co.uk
I read somewhere that pressure should be at 5 lbs at all times which I thought was very high . I usually run mine around 3. But I read that pressure can be increased if fully loaded. If so, to what level? Some sound advice will be appreciated. Thank you.Run ours between 2.5.and 3 bar do not run at Full or empty!
5 lbs? Typo? do you mean 5 bar?I read somewhere that pressure should be at 5 lbs at all times which I thought was very high . I usually run mine around 3. But I read that pressure can be increased if fully loaded. If so, to what level? Some sound advice will be appreciated. Thank you.
Thank you for answering my unasked question, I'd been musing over that scenario.i run ours at just over 2 bar ( 30 psi) a word of caution:- do not jack up the body with more than 5 psi in the bags it can cause the bags damage as the axle is pushed away from the body and stretches the bags.
it is ok to jack under the axle with any pressure as that is the same as the wheels being in contact with the road.
Thank you Mike. Yes I meant 5 bar. I have always used it between 2.5 and 3 bar. When I am fully loaded with ebikes, I go up to 4 but that is MAX.5 lbs? Typo? do you mean 5 bar?
5bar , [ 71 psi, approx] yes that's very high, somewhere between 2-4 bar normally finds the sweet spot, experiment with your van, to low= wallowing, to high= goodbye fillings.
Mike.
I have no built in compressor. Are the air bags connected to a T pipe so the pressure is measured at the same place and when inflating / deflating both bags are adjusted at the same time?Hi, my system is much simpler with no on-board compressor. However, yes it sounds like the sensor. I have a sensor on each air bag, and have noted that when one unloads at roundabouts, or odd road cambers, I get an audible warning, but it stops as soon as the plot levels out. Hopefully others will be of more assistance.
Mike.
Hi, yes separate line for each bag.I used a 6 wheel tyre pal type system with 2 of the 6 sensors monitoring the air bags.PS: or if they are independent then its likely you need to up the pressures.
Thank you Mike. Do you happen to know where the sensor is located? Can it be changed?Hi, my system is much simpler with no on-board compressor. However, yes it sounds like the sensor. I have a sensor on each air bag, and have noted that when one unloads at roundabouts, or odd road cambers, I get an audible warning, but it stops as soon as the plot levels out. Hopefully others will be of more assistance.
Mike.
Good idea using tyrepal to monitor the pressureHi, yes separate line for each bag.I used a 6 wheel tyre pal type system with 2 of the 6 sensors monitoring the air bags.
I think the load comes off the side not being leant on, you can certainly feel the van has less wallowing in corners, and is all-round a nicer ride.
Mike.
Hi, no unfortunately. Perhaps a call to Goldschmitt in the first instance may be helpful, but a sticky sensor sounds like the culprit.Thank you Mike. Do you happen to know where the sensor is located? Can it be changed?
Hi Mike. The call to Goldschmitt was extremely helpful. I spoke to a technician in the Workshop who knew exactly what the problem was. He clearly identified the problem, being a faulty manometer. I can drive the van but these 2 need to be changed as soon as I can. I ordered 2 "manometers" with the Parts Department. I will call them tomorrow to find out when it will be delivered. The technician clearly advised that the pressure should be normally between 2.5 and 3 bars. But when fully loaded, I can go up to 5 bars. So hopefully the problem is sorted now. Thanks for your help. Happy camping Kind regards. MouradHi, no unfortunately. Perhaps a call to Goldschmitt in the first instance may be helpful, but a sticky sensor sounds like the culprit.
Is there a light, or any other indication when the compressor is running? To know that might be useful, it could/would rule out other components being faulty.
Mike.
