Air Con Re-gas
Harmony line 690g
Just had the Burstner 690g A/C regassed (Fiat Ducato) 2019 , was surprised it was the Old Gas in her, thought it would have been the Later Gas as it is a 2019 M/Yr .£60 instead of £120 for the new stuff so Happy with that.
Same with mine 2019. Don't know where it went. What a difference though.
People don't realise that the aircon on any vehicle should be operated regularly, even in Winter , I have always put mine on regularly as the Oil in the Gas stops the Seals from Drying out, which is what causes the Gas to leak as the Seals crack if not Lubricated. 👍
Hi Burge. I have a Burstner Ixeo i720 A class 2019 2.3 diesel. I have taken it to 2 garages & both have said they need to know how many grams to put in. I know it’s the old gas like yours but do you have any idea how many grams it takes? Both said if they put in to little or to much it can do damage. Hope you can help
It does say on the label under the Bonnet how much gas it takes , my Garage said it didn't seem a lot on mine but put in what it said , it took 50g out & put 550g in ,this is the printout they gave me
Always leave it permantly turned on in both car and Motorhome. Last Motorhome it was still working fine at 7 years old, still working in the car at 13 years old.
Had an VXR Nurburgring bought it 2yrs old , Aircon Condenser missing bottom part, fitted a New Condenser Gassed it up lasted till I sold her last yr 14yrs on still perfect , that was doing the Same as you , using the A/C regularly 👍
Thanks for the chart. The label under my bonnet doesn’t exist, that’s why the garages were not happy about filling. I will take the chart into them next week. Thanks again, most helpful
To be on the safe side , I would give Fiat a call with your Van details ie Vin No ect , they should be able to give you the exact Content for all Fluid Levels .👍
Reactions: GAA
