Air Con on 2000 Hymer / Ducatto Chassis
Petersfield, UK
Hymer B574 A class
A returner after a 10 year gap
We have a 2000 Hymer B574 on a Ducatto chassis. The factory fitted air con is duff and needs a new compressor and condenser.
Fiat can supply the compressor for £1,500! The condenser is not available at all. So far, only my excellent mechanic has been on the task.
Can anyone suggest a specialist or other supplier who might be able to help, or even how to find the correct Fiat part numbers to look for aftermarket or rebuilt parts.
Thanks folks.
Thanks folks.
Should be able to get something !
May I suggest if your man cannot source the parts he may be the wrong man!
ebay have lots of choice on condensers and I suggest you may not need a compressor as some of them will not engage if there is no gas in the system, certainly was the case in my Mercedes’ which I had repaired a month ago.
Condenser cost me £52, regas £40 and fitting £40 so all in all a cheap fix
I put my 2002 b524 to the garage to sort the aircon. Condenser was okay but the a/c guy said probably worth changing it. Garage found that part no problem but fiat don't make the high pressure hose anymore (mine had a hole in it) so they apparently couldn't fix it.
The fiat professional (?) website can find the parts if you enter your VIN number. It can be a little frustrating using it though.
Don't think the condenser will be too hard to find.
