- Jan 4, 2023
- 2
- 0
- Dethleffs
Just wondering has anyone had the same problem with the ECU light on the dashboard and how can it be repaired or maybe reset.?
Graham
Graham
Just a thought is the Horn workingJust wondering has anyone had the same problem with the ECU light on the dashboard and how can it be repaired or maybe reset.?
Graham
Take a look on flea bay there is one that charges £55.Hi thanks for all your help.
Has anyone got any information regarding company’s that can repair an ECU airbag fault for a Fiat Ducato.
Graham
See the other thread but Best just to get a new one fitted with a 2 year warranty.Hi I am new to this forum but alas am finding that a lot of you have this ECU air bag light problem. I DO,! I have tried al sorts including sending off my unit to Crash Data reset. They reset it and its worked for a year.
I have found that if the warning lights are lit, then after a while ,when the cab warms up that the warning light above the drinks holder ( ducato 2015 model ) goes off. The one on the dash stays on ??? Checked all wire under the seats etc. No good, going to try some contact grease next on the plugs.
I would however like to have a wiring diagram for the fuse box/air bag system, if anyone knows where to download one i should be very grateful.
There seems to be a bit of contention about the power from the battery High/Low so am in process of checking that out.
The positioning of the ECU under the drinks holder??? I am going to try fitting a seperate earth wire to the box and insulating the box itself and leaving it loose in the cab. This area is extreemly cold in winter and it seems to be worse in cold weather.
I have read somewhere that ordinary vans that are being used daily do not suffer this problem. Only vans that are being laid up for long periods ,like motorhomes.
I do agree with people that Fiat should have done something about it but it seems to be the world we live in, make a fast buck with no service following up.
Last year to get it through the MOT i actually put a bit of black tape over the light on the dashboard, it got through, it was only temporary until i found an answere. Which I have NOT , YET, Will let you know my findings.
Hi Graham.Just wondering has anyone had the same problem with the ECU light on the dashboard and how can it be repaired or maybe reset.
Graham
Fiat will charge you around £120 to reprogram it to your van.Hi Graham.
i had the same issues. I sent Airbag ECU module off to CrashData about 3 Years ago. Came back fitted it and all was ok for a few months over summer. The cold weather seemed to make it fail again.
Problem seems to be one of three things.
1). Unit getting condensate problem when used in cold months. ( very cold in that area when you have heating in the motorhome )
2). Spike on your battery. ( high or low ).
3). ECU failure.
It seems as if a reset does the trick.It Doesnt,? if all the leads under the seat are ok and it has been checked out, YES you can get a fault code, but all it does is wipe the fault off. The trouble persists. £ 80 plus postage. Some one to fit it.?? Its not worth it.
I have found a company who sells the upgraded version for £235 inc and delivered.It covers about 4 ECU part numbers.
I have sent for one and although I have to get someone to program it back into my van, it seems to be the only option. If its an upgrade then hopefully Fiat have got hold of the trouble and sorted it out.
Its due soon so will let you know.
Cheers Des.
Has anyone tried warming up the cab area after a storage period and then starting the van ,with a warm cab ( and warmed airbag ecu) or has the damage been done?
Can we not just buy the "Flash" machine that Crashdata uses and then never have to worry about this issue raising it's head every month? Does anyone know where to look for the hardware and software? Crashdata bought it from someone. I would assume we could too.Take a look here……..
Fiat ducato air bag warning light is on…..AGAIN.
For the 3rd time in less than 12 months the air bag warning light is back on the dash.The last time was 6 weeks ago when it cost me £88 with crashdata to have the module reprogrammed.I did ask the question then why has it gone again.One of the replies it could be high voltage when starting the...www.motorhomefun.co.uk
