I removed ours... wasn't stuck. Just bolted...I imagine yours is a tight fit...try pulling directly upwards with a slight knock...Good luck fellow Hymer Owner...I am in the process of removing my Hymer table.
I have unscrewed the four bolts but table doesn’t want to budge. Are they glued in place as well as bolted?
I intend to look under the flooring next?
I have given the table a knock previously and nothing happened. I will give this a go. ThanksThere has been a lot of chat lately by me and others about this. Try introducing a rigid scraper under the table base. I did it this way without damaging the floor in any way. The scraper was "introduced" with a mallet!
Nice one. I will give that a go. ThanksI used a bit of heat, hairdryer around the base then a good shove.
That sounds like a very good idea.I used a bit of heat, hairdryer around the base then a good shove.
A few questions. Is your scraper reasonably wide? Did you get the scraper well in? Have you tried piggy-backing a second scraper next to the first? My base did not budge until I did that. Perhaps a combination of Detnor's technique and a scraper might work. I didn't say it was easy! My concern was damaging the floor but, apart from the slight dent caused when I tried levering it up, there was no damage at all. Your flooring might be better quality than our Pilote too. Good luck.I am still not having any luck removing the table. I have tried knocking a scraper between bottom plate and floor but no luck.
Any more ideas?
It sounded like a good idea straight away. Pleased that it worked for you and that the better half is happy. Did it leave a location hole in the floor or just the screw holes? Ours left a circular patch of floor a somewhat different colour after being hidden from light for years and the 6 screw holes.
