advice needed re mifi and antenna
MaidinDevon
Bromyard, Herefordshire, UK
Hymer B654
since 2010
HI all
Forgive me, I have read lots of threads about this, but just managed to confuse myself completely. Can someone point me in the right direction?
This is my problem. We live in the van and most of the time we are on a site in Devon which has wifi. We pay 12 per month for this, which is OK. However, once the blinds are up at night the signal gets a bit iffy. We can only use it on one device at a time, and would like to be able to use several.
We have an iphone which I have managed to tether to the laptop, but due to the location very poor signal on 02. However, this is the best phone signal for our area.
The kindle 3g is also poor signal - I think this is the vodafone network. (Is this the same as EE?)
I bought the huawei mifi, hoping to use that, as it can be balanced on a skylight. However, EE signal is also very poor, and drops in and out. I have the unlock code now, so will try to do that, but still dont know which network to try instead.
Would a booster, or antenna help with the poor signal.
Can I access the site wifi through the mifi, allowing us to use more than one
The site is in a steep sided river valley with lots of trees around us. It is very pretty!
Any help much appreciated.
Can I access the site wifi through the mifi, allowing us to use more than one.
No not through MiFi.
You may get site WiFi with an exterior aerial. That solution is on here, two in fact, an ebay one or our member motorhomewifi.com. Both very similar in use to MiFi but using a local WiFi hot spot ( the site in this case ).
sounds like you are in hidden valley site just up the road from me.
I use a booster system, about £20 from t'internet.
This is my review on the said article.
Russell
The OP needs the router to go with that that then feeds several computers via WiFi. All on ebay. Though I've not tried it personally.
Russell
We have a booster like the one Russell has linked to and find it excellent. In the situation the OP mentions concerning pulling the blinds down at night - we have our booster in the small holster attached to the inside of the window. Interestingly, when the blinds come down over the top of the booster it often appears to amplify the signal even more.
We have used this method during the daytime on occasion when the connection - even using the booster - is marginal. Just pull the blind down over the booster and watch the signal strength improve! Doesn't work every time, but it's always worth a try. :thumb:
Mike
your MiFi MAY work better if you do as Jim (ringleader) does.....put it in a plastic bag and hoist it to the top of a flagpole.
otherwise unlock and buy a 3 'data only' simcard
I'd be tempted to try the 'hoisting up a flagpole' trick, or some other method to raise your MIFI to hopefully receive a better signal before spending money on anything else as that may be all that it needs. If that doesn't help much have a look at the 'coverage check' for each provider for where you are - as you know how abysmal some of them are already it will give you some idea if moving to '3' will be any better, you could then see if someone has a '3' sim which you could try connecting to, or try in your MIFI (once you've unlocked it) and see if it works any better, then if it is, you could consider buying a '3' sim. There are also various 'GiffGaff' data sims too but you'd best check which network they work with/their coverage:
http://giffgaff.com/goodybags#data
http://community.giffgaff.com/t5/Solve-your-questions/How-do-I-check-coverage/ta-p/3487749
Hi Wildman
Actually we are in Horrabridge, at Magpie Leisure Park. It's a lovely spot, Thanks all for the help. I will try the tupperware outside, but not tonight, as it is a bit windy, and raining cats and dogs. Giff gaff says they have good 3g, and 3 seems reasonable, according to their coverage checker, but green, which is outside. I have the unlock code, so will have a go at that soon, and then experiment. I presume if I buy an antenna, it would have to plug in to the mifi. Tricky if it is in a tupperware box. One step at a time I think.
Hi Wildman
Hi Karen, Don't go with GiffGaff they use the O2 network as well so you wouldn't be any better off. I know this as Jean has a giffgaff sim and I'm an agent for them.
Are you off South this winter? if so we may get to see you down there at some point.
Keith & Jean
Hi Wildman
The antenna actually screws into the side of the unit, there's an unmarked black cover if you look carefully and lift it you'll see the screw thread. :Smile:
Funnily enough they invented something to solve the problem of the antenna lead getting into Tupperware boxes ... it's called a drill bit!!!! :BigGrin: You do have to know how to work power tools though in order to use it! :Rofl1:
But if that's a bit toooooooo technical for you ... :Doh: .... another option I would think is a waterproof phone case as you can use that when you're out for your phone etc too ... there are loads on Ebay, something like this:
Link Removed
Hi Kieth
Thanks for the tip about giff gaff. I am working at the moment for an Agency, the contract is until Mid January, and then we will be heading for Portugal for 3/4 months. Looking forward to it no end. Dont know where yet, although we may join the rally in Albufeira for a bit if it comes off. When are you off? It would be nice to catch up somewhere. We will definitely spend some time in Portimao, and Silves.
Karen
