WESTY66
- Jun 17, 2017
- 7,309
- 20,082
- Carthago Chic C-Line
- All the gear, and no idea!
Ok im not splicing anything but I’m after advice off you electrical gurus.
I’m going to install my Votronic MPP350 and Votronic display.
Pic1 is the controller I have at the moment in the upper locker
Pic 2 is the locker position
Pic 3 is the battery compartment directly under the locker with the controller in at floor level obviously.
and pic 4 is the perspective of locations I want to do the work in.
So far so good, now would you put the MPP350 in the locker as a straight replacement location and run any wires to it? If so would the wires from there to the batts need beefing up? Or would you relocate the MPP350 into the batt compartment and run any wires to and from it there? I was thinking at the side of hole where a cig lighter charger has been sawn out (not by me) and would I need to beef the wires up running from the SP to the MPP350 and also the short wires to the battery? I also have a battery temp sensor, where would you site that?
Finally I was thinking of mounting the control display in the Black panel above the door I’m assuming it’s the best place for it?
Sorry for the questions, I only want to do it once so needs to be right!
Thanks Ady
Thanks Ady
