Adria water pump location
Mrsheridan
SOSmtrhm73!
anyone know the water pump location on a 06 renault master adria izola s687 sp? Or why my interior lights & pump have stopped working, truma heater & fridge freezer & external light works, lt500 ctrl panel seems to work fine and ive checked elektroblok ebl 225 ports with multimeter, seems ok, as well as in line fuse on leisure battery
No idea on your model but look in one of the wardrobe spaces there may be a lift out panel that give access, normal on Adrias
Under the drawer that's under the fridge freezer on ours ... The draw unclips from underneath
Im nonstranger to campers but i have lookwd absolutely everywhere and still canmot find the pump, its not beside the boiler under bed, not under the fridge, not beside the tank, have literally lifted every panel i can and still bewildered,
I assume water tank is under bench seat, an if so all water is on one side of van and would expect your pump to be kitchen area or under wardrobe
The water pump is in the top of the tank on an Adria A70DK
Adria have a knack of hiding stuff, spent a day looking for the automatic step relay,
Started at the warning light/Buzzer in the Cab and following the wiring as best as I could into the back,
Went way past the step and eventually found it hid on the floor at the back of the gas hob,
My knees will recover eventually 😩
I once had a Jonckheere Coach for doing the Express runs to Spain, Italy and the South of France.
The wiring on that depended on, what day it was manufactured and who the Electrician (or team) was.
They refused to issue wiring diagrams, simply because they didn't know.
It was a nightmare! 🤬
As a person who believes in reliability above most anything else, it didn't stay with me long!
