Adria supersonic solar panel
You should be able to tell if you look at the solar controller. Our Adria Compact charges both.
Was the solar factory fitted?
If you mean switched off at the control panel then yes. Can you post a photo of your solar controller to see if we can determine if it is wired to charge both leisure and starter batteries.
Cool yes that would be great, I'm not back with the MH till Friday so will take a picture then. Thank you
