Adria matrix control panel
South Wales, aberdare, UK
Adria matrix
8years
Up to three weeks ago b1 and b2 both illuminated now only b2 illuminated, all batteries reading 100%, it’s the same if plugged in to the mains. Any one come across this or know why. Solar panel seams to be working ok the sun control seams to be doing what it should do. Or is there a fault with the control panel?
Odd. Nothing relevant in Troubleshooting.
Maybe a quick call to your local Adria dealer?
Sounds like the control panel is faulty. Dealer might be able to swap with another if they have one with the same panel. There's nothing that can easily be repaired on them but they are easily swapped or if you want to risk buying a replacement they just pull off. They are held on with velcro and a couple of clips. There's only a few cables on the back.
Have you tried powering it off completely. Either by taking the cables off the back or disconnecting the JP6 plug on the Nordelectrica unit or disconnect the leisure battery?
