Adria coral ceiling lights
Euromobil
hampshire
Adria Coral
Since 2010
My 2012 Adria ceiling light has failed, it is oblong with 4 downlighters (maybe led) in the middle is the on off switch which can glow blue as a night light. This blue still works so I assume there is still power to the light. All other internal lights still work.
So please 1) ideas as to problem 2) how do I remove the unit, I can't see any fixings
A quick bump as you haven't received any responses.
Dies the white surround unclip in any way? That seems to be the logical way that any fixings would be hidden?
Our 2012 coral has the blue and white leds but a different light fitting to yours.
The white surround should unclip ( carefully) 🤔
If all of the white LEDs are not working then it could be a connection to them or part of an internal circuit board.
PS: only time we use the blue light is if it’s switched on by mistake 🤭
Thanks both, well I took a deep breath and slid a large screwdriver under one end, a gentle twist and off popped the white cover.
A well known online auction house provided a very similar unit that covered the previous screw holes.
