Adria compact supreme suspension?
Leicester, UK
Adria Supersonic 780
Couple of questions if anyone can help? I have a 2021 adria compact supreme which is fitted with HPC levellers (brilliant bit of kit by the way). I was thinking of fitting semi air to the rear but I’m not sure if the adria is on a Alko chassis or not, is there a easy way of telling? Also if I fit the semi air on the rear, is there a possibility of over extending the air bags when the levellers do there extending. Thanks
If you look underneath and see leaf springs it is not an Alko chassis.
Reactions: f6c
We have a Adria coral and it’s not on a Alko chassis also have EP levellers and rear semi air , before you use the levellers you have to let the air out of the semi air.
Thanks, looks like it’s a fiat chassis then 👍
T
Thanks , I thought that might be the case, I’ll have a word with AS at warrington to see if it can be integrated with the HPC system.
