- Jun 29, 2015
- 3,865
- 63,949
- caravan (for now)
- on and off since 1984
Like the title will a 10amp fuse be enough for a 100w solar, the fuse is off the battery before the control.
Your fuse is at the wrong end of the cable, it should be close to the controller as that is where the current is flowing from.Like the title will a 10amp fuse be enough for a 100w solar, the fuse is off the battery before the control.
Fuses are to protect the cable 10 amp will be OK.
But that doesn't protect the cable if there is a short between the battery and the controller, rightly or wrongly ours is fused where the solar regulator cable joins the +ve bus bar and the original controllers had a fuse in as well (not sure Victron does).Your fuse is at the wrong end of the cable, it should be close to the controller as that is where the current is flowing from.
You don't normally fuse solar panels it is not required but most of us fit a fuse by the controller as a convenient way of disconnecting the panels.Would you not agree with the fuse layout I gave in #2 ?
I would agree it is wise to have one at the battery end as well as the battery is an infinite source of power.But that doesn't protect the cable if there is a short between the battery and the controller, rightly or wrongly ours is fused where the solar regulator cable joins the +ve bus bar and the original controllers had a fuse in as well (not sure Victron does).
Basically it's connecting a power source to a power source so I can see an argument for a fuse at either end
Is that on the basis that the cable from the solar is more than capable of handling even a dead short on the panel supply side?You don't normally fuse solar panels it is not required but most of us fit a fuse by the controller as a convenient way of disconnecting the panels.
So the fuse is the battery end of the cigar lighter socket wiring, I would say that was fine "but I know nothing" there is most likely a fuse on the back of the panel anyway.Following on from my last post, the solar is for my caravan and it's a suitcase type, to connect to the battery I fitted a cigar lighter type socket to the battery that's where the fuse is.
You can short circuit a solar panel and it won't cause any problems.Is that on the basis that the cable from the solar is more than capable of handling even a dead short on the panel supply side?
As Lenny HB says. If you look at the solar panel specs, you will see 'Imp', the amps at the maximum power point, ie the normal working amps. Also there will be 'Isc', the amps when short circuited. Isc is not much more than Imp, so any fuse that is OK for Imp would never blow if it increased to Isc.Is that on the basis that the cable from the solar is more than capable of handling even a dead short on the panel supply side?
Not quite infinite but enough to cause a fire. I used the prewiring on mine and have to confess assumed the battery end would be fuse protected rather than checked I did put a fuse near the controller to isolate it if necessary but inside the motorhome.I would agree it is wise to have one at the battery end as well as the battery is an infinite source of power.
Just a thought in general terms a fuse is not just to protect a cable but if there is an overload in a circuit which may or may not include a length of cable. I am not an electrician but observing where manufactures place a fuse it appears more about overall overload protection which may be at any point along a circuit from the power lines incoming main fuse, fuse box, plug and internally with a device.Your fuse is at the wrong end of the cable, it should be close to the controller as that is where the current is flowing from.
Covered in earlier posts.Just a thought in general terms a fuse is not just to protect a cable but if there is an overload in a circuit which may or may not include a length of cable. I am not an electrician but observing where manufactures place a fuse it appears more about overall overload protection which may be at any point along a circuit from the power lines incoming main fuse, fuse box, plug and internally with a device.
He says that whether you need to add fuses depends on the 'Maximum Series Fuse Rating' parameter. That supplier Rich Solar gives this in the spec list, I don't know anyone else that lists it. I'm sure he's thinking about arrays of 4 or more panels, so not applicable to most MHs anyway.I don't know if this is right or wrong but it's certainly interesting
