Not the cheapest around, but not wanting to spend time trying Aldi/Lidl/etc to see who might have it cheap, I just went to Halfords. Sometimes you have to realise that if you spend 30 minutes looking to save £5, you are making less than the minimum wage...
I’d like to know what would/might happen if you did this as wellA thought has just occurred to me? Whe the ad blue low level light comes on if you fill it with water how does it know?
the sensors just detect the level they aren't capable of testing the fluid?
Filling with water is a myth,and will caused you problems,it is NOT PIG URINE,I used to hear that every day! Adblue is 30 %urea and rest is deionised water, your nox ( nitrous oxide)sensor will pick up high nox reading flagging up eml\ Adblue fault, I have worked for an Adblue manufacture,I used to deliver Adblue in bulk so know a thing or two about this stuff.if it’s sold as Adblue it’s been made to very exacting standards set by the patent holder for Adblue, def or diesel exhaust fluid is often similar but not under strict licence rulingA thought has just occurred to me? Whe the ad blue low level light comes on if you fill it with water how does it know?
when the adblu e is added it converts the gases in to Nh3 & Co2 . i wonder whether the addition of ammonia to fill the adblue tank would fool the Nox sensor . No real interest just wondering what could be used in the event of a lack of adblue?Filling with water is a myth,and will caused you problems,it is NOT PIG URINE,I used to hear that every day! Adblue is 30 %urea and rest is deionised water, your nox ( nitrous oxide)sensor will pick up high nox reading flagging up eml\ Adblue fault, I have worked for an Adblue manufacture,I used to deliver Adblue in bulk so know a thing or two about this stuff.if it’s sold as Adblue it’s been made to very exacting standards set by the patent holder for Adblue, def or diesel exhaust fluid is often similar but not under strict licence ruling
