Hi All
I need to replace my blown brake light bulb on my Auto cruise Rhythm Compact panal van.I need to get access via the plastic panel but unsure how to remove the piece that holds the panel in place.Enclosed a picture of the problem.Any help would be appreciated.
You need to prize the centre of the button out, a scalpel or craft knife will usually do it and then you will find a screw underneath, looking at your picture that centre has been out before so it shouldn't be too difficult.
If there is no screw when you get the middle bit out it will be a 'pop' fit where the centre bit pushes the back out so the back bit opens bit like a wall plug.
There's probably a technical name for that type of fitting but don't know what it is.
I had to take the whole rear light fitting out on previous van - what a pain in the a**e that was.
