7Hvn
I recently purchased a VW Up with an existing smart tow a-frame setup.
Ever since I’ve purchased the vehicle it’s had a noticeable knock at the front end.
I took it to my local independent and asked them to check the suspension, engine and gearbox mounts.
Turns out it’s the near side steering ball joint is kaput with masses of play.
On a vehicle with ~14k recorded miles I would typically have found this rather odd but since it’s been towed probably a good few thousand miles it makes sense.
The garage said they had very rarely had to change them on ups and citigos and certainly never with so little mileage.
So a question to you other A Frame folk - have you observed similar issues with steering ball joints or other components prematurely failing with the suspect believed to be as a result of the vehicle being towed with an A Frame??
PS - No A-Frame politics please!
