Thanks for reply , I also use a buggy from seat to brake pedal but still happens , iam sure it is well greasedSimilar happened for me with my first overrun a frame, I would brake to a stop and until I pulled away the coupling would stay compressed keeping the lights on.
Assuming you have an overrun hitch, I used a bungy from drivers seat to brake pedal to help pedal return and finally I fitted a disconnect coupling to the toads battery ensuring that all battery drain was from the motorhome.
Btw the car was a Peugeot 107 so much the same as yours.
it made my front brakes stick on you have to unclip it from the brake pedal then pull it through good luckThanks I will check it out![]()
