Clickem
That I would appreciate any advice with:
Small rear window blind seems to have lost it’s friction that keeps it up. Is there any way of tightening it up?
We have a Veba AV70mm screen and reversing camera. The screen is operated by a remote and has 2 channels. Ch1 is operated when the reverse gear is selected and Ch2 is on constantly (with ignition). Sometimes the screen works fine and sometimes it does not work at all, which is annoying if you suddenly need to reverse. When reversing, and not working, if I switch it to Ch2 it usually works and then switch back to Ch1, it still works, until out of reverse gear, or it may go off after a short while
I think that it must be a screen fault, as it can usually be made to work. Any pointers before I learn to put up with it, or splash out - the screen can be bought from Amazon for £110
