- Dec 24, 2014
- 10,262
- 55,035
- Compass Navigator
- Ever since lighting was by Calor gas.
I can't fathom this teaser out and I am of curious nature so need to know.
I use a 5kg Calor Patio gas cylinder for my BBQ but the flame had dwindled to the extent that this morning I decided to exchange it for a refilled one.
However, to my surprise I could feel that there was still a significant amount of liquid sloshing around inside it and the built-in gauge on the cylinder showed just over 1/3rd full. It's an internal float operated gauge which I know isn't particularly accurate so in order to assuage my curiosity I weighed the used one and later the new one with the following results in Kg......
Gross weight of used bottle was 9.10kg and the Gross weight of the new bottle was 12.50kg.
Tare weight of the used bottle was 7.26kg and the Tare weight of the new bottle was 7.31kg.
Therefore the weight of liquid gas in the used bottle was 1.84kg and the weight of liquid gas in the new bottle was 5.19kg.
This means that my part-used 5kg bottle still had 1.84kg of liquid gas remaining even though the BBQ flame was dying.
The new bottle was full with 5.19kg as it should be.
My ponderings are............
That the BBQ flame using the part used bottle shouldn't diminish all the while there is liquid remaining because as gas is drawn off and the pressure drops the remaining liquid will gasify until pressure is restored to the point where no more liquid will gasify until the pressure drops again. This being so the BBQ flame should remain of constant magnitude all the while there is liquid gas in the bottle, but my flame was dwindling even though 1.84kg (nearly 1/3rd of a full bottle) of liquid gas remained un-gasified. At £23 a pop the remaining (unusable) third of a bottle (1.84kg) is not to be sneezed at.
My only thought is that my regulator which attaches to the top of the bottle is faulty and yet with the new bottle the flame is back to its normal strength.
