coastal motorhomes but the gears are very scarce now I bought the higher set last year and think it was there last set
There are 2 ratio’s for the 5 gear can’t tell you the number of teeth though.
We have the same year Motorhome
I've replaced the 5th gear synchro now, the only fault on the old one I took off, was a spring seemed deformed, the new synchro works fine (finger crossed). The job was pretty easy, took me about 4-5 hours most of which was trying to drive the split pin out of the selector fork. If anyone is doing this, make sure you have a 4mm diameter steel rod about 10cm long to use as a drift, I filed the rod on the end to make a 1.5mm diameter pip about 2mm long, this located the drift onto the split pin and made life a lot easier. The gears themselves were fine, the original problem I had was crunching when selecting 5th, it stayed in gear ok, and my gear ratio was 53 x 31, this is on a 2003 2.8JTD Ducato with an MLGU gearbox.
