So, it would seem that this is the best thing to fix solar panels to a roof with, but where’s the best place to buy it from? Also, what thickness is best to use?
Ta.
Ta.
Ta.
I used 50x50x3 for mine. It's probably over engineered as 2mm thick would do. I also used rivnuts to secure the panel to the angle. That way I can take it out easily if needed. I also bought a panelSo, it would seem that this is the best thing to fix solar panels to a roof with, but where’s the best place to buy it from? Also, what thickness is best to use?
Ta.
I used these for my panels , when placed fore and aft they stop the wind getting under when moving, and a nice wide adhesive area. https://www.photonicuniverse.com/en...ls-to-motorhomes-caravans-boats-or-roofs.htmlSo, it would seem that this is the best thing to fix solar panels to a roof with, but where’s the best place to buy it from? Also, what thickness is best to use?
Ta.
As above???Can I ask each of you who have used Ali, why did you pick the size you did? I have some 20x20 which feels big enough and strong enough for the job.
50 x 50 gives a reasonable contact area for the adhesive I wouldn't want to go smaller.Can I ask each of you who have used Ali, why did you pick the size you did? I have some 20x20 which feels big enough and strong enough for the job.
Ooh, that’s interesting…… I work in Droitwich!I use Droitwich aluminium they are on ebay and delivery. I find them cheaper if you phone and pay when you collect.
Paul
