No switch in the control panel? Can you power off the entire control panel? Are any of the connections to the pump in the water?Is there any easy way of turning off when replacing a fuse, or is that not necessary? Ta.
If pump wiring is easily accessible disconnect the pump and try a new fuse, from memory just the pump is on that circuit.Hi, fuse under passenger seat is blowing as fast as I can put them in. It's the first fuse in. No idea where to start fault finding ... no water to taps or toiletany hints / ideas please?
Most motor pumps run at about 5 amps but will have a current search around about 7 to 8 amps which is probably why you keep blowing fuses I would fit 10 amp fuse has running the pump and a toilet at the same time will probably come close to itIf pump wiring is easily accessible disconnect the pump and try a new fuse, from memory just the pump is on that circuit.
Mike
Post #8, OP tried 10 amp.Most motor pumps run at about 5 amps but will have a current search around about 7 to 8 amps which is probably why you keep blowing fuses I would fit 10 amp fuse has running the pump and a toilet at the same time will probably come close to it
Continually blowing a fuse is a PITA - whenever I'm confronted with this problem I replace the fuse with a resettable fuse for the purposes of testing and replace with a standard fuse when the fault has been rectified. Resettable fuses are available on Amazon of course.Hi, fuse under passenger seat is blowing as fast as I can put them in. It's the first fuse in. No idea where to start fault finding ... no water to taps or toiletany hints / ideas please?
