Hi, does the fridge run off the hab battery once the engine is turned off.
My 3-way, manual selection, will only use 12V whilst the engine is running.It shouldn’t do. If it’s got auto select it should pick 240v if you are on hook up or gas if not. Without auto select you select yourself. I think if you don’t change from 12 v, in those circumstances, it will continue on the leisure battery and flatten it!
Not having any problems, but we are going on a longish trip and want to just use gas for cooking, while off grid.not usually, but some can run off 12v via the battery and solar - with an auto selection ....
hopefully someone will be around to confirm
are you having an issue or just asking?
I have a 3000w lithium battery, not sure of its Ah. With 400w solar panel.Unless you have ample Lithium and plenty of solar it’s not going to happen,
3 way fridges take upwards of 15 amp per hour so will easily kill a leisure battery overnight,
We have a Rapido 8086df,What van have you got?
I can run mine off inverter so long as there's enough sun to replace what I'm taking out (15a) and can run direct off the batteries if I change the CBE unit but again you need to watch what it uses as 15a is a lot to replace.
Are you sure , batteries normally rated in AHI have a 3000w lithium battery, not sure of its Ah. With 400w solar panel.
Ok well our 300 amp lithium would deplete by a third overnight and the 500 W solar would put most of it back if there was plenty of sun, but we used a 50 amp B to B charger to top the battery off properly,I have a 3000w lithium battery, not sure of its Ah. With 400w solar panel.
The fact you are asking suggests that you have a 3 way fridge. In that case, No. it will run off gas, or EHU, when the engine is turned off.Hi, does the fridge run off the hab battery once the engine is turned off.
To work out how long it would run the fridge, you will need to find the AmpereHour (Ah) capacity of the battery. The Watts figure is meaningless in a motorhome environment.I have a 3000w lithium battery, not sure of its Ah. With 400w solar panel.
3-way fridges burn 15 amps continually whilst they are on so leaving it overnight on will take 150 AmpereHour out of the battery.3 way fridges take upwards of 15 amp per hour so will easily kill a leisure battery overnight,
It's a mastervolt advanced lithium system. It's quite good apparently, but above my headThe fact you are asking suggests that you have a 3 way fridge. In that case, No. it will run off gas, or EHU, when the engine is turned off.
If the battery is the 300 watt Lithium-ion battery from Power Republic then that is the wrong sort of battery for motorhomes. I would seriously recommend that you change for a LiFePO4 battery.
15 amps x 10 hours.
Or sell the fridge you have get 1.a 240v fridge and dedicated inverter circa £200/£250 or2. a 12v fridge £450 up..but either gives a far better performance than a 3 way in high ambient temps and can be left on during long ferry crossingsMost cost effective would be refillable bottles, or double your lithium,
I doubt it cos Spain is on the Mediterranean and atlanticNot sure if we will be able to pick up Spanish bottles around the Adriatic cast.
Maybe I should look into getting refillable bottles.
My 2024 Thetford trivalent fridge works on 240 when plugged in, gas when not, and vehicle battery (alternator) while driving (but while driving will only maintain the temperature, so if you fill it with warm beer it does not cool it) all the time it is on auto. There is a delay of 15 minutes after switching of the engine before the gas will fire up, to avoid it starting while in a petrol station. You can manually select the power source you prefer any time, but I just leave it on auto and it works perfectly.Hi, does the fridge run off the hab battery once the engine is turned off.
Thanks BarrieMy 2024 Thetford trivalent fridge works on 240 when plugged in, gas when not, and vehicle battery (alternator) while driving (but while driving will only maintain the temperature, so if you fill it with warm beer it does not cool it) all the time it is on auto. There is a delay of 15 minutes after switching of the engine before the gas will fire up, to avoid it starting while in a petrol station. You can manually select the power source you prefer any time, but I just leave it on auto and it works perfectly.
Gran Canaria, Canary Islands, Spain (Africa really).3-4 month trip away from your own country, definitely refillable.
Barriesimpson can recommend a place in Northern Spain, I'm not sure where you are?
