3 way fridge problem on Gas after running for a while.
Bristol, UK
Hymer B614SL
since 2020
Hi,
I’ve a 14 year old Dometic 3 way fridge. Works fine on EHU and 12V. It also works fine for about a day on Gas and then won’t relight.
I can hear it ‘clicking’ to try and ignite the gas but it won’t light.
It can’t be a gas supply issue as it works fine for a day and then seems to ‘give up’. Heating and burners are also working well.
I took it to Dometic but as it starts fine when it’s been left a while, they couldn’t find a fault but they did change the burner as it was a bit rusty.
Any thoughts on what could be the issue is most welcome.
Thanks.
It could be the gas supply solenoid valve , try giving it a tap next time it stops working , if it then works that will be the problem, a sticking valve , needing replacement.
There are answers to a similar problem in the gas section of the Motorhome life support systems forum section on here which may be useful.
