3.5Amp - 4-5Amp with nothing turned on ?
Derbyshire, UK
Bailey Autograph
Since 2016
Is this the amps going in from the solar panel? Or is this a drain?
Sounds a lot for a single 100watt panel in winter. But with nothing turned on other than the control panel and fridge running on gas it sounds a hell of a drain. In fact with a single 110amp battery I’d be flat in 12 hours running nothing.
Does look like input but rather high for just a 100 watt panel this time of year, that's all I get from 300 watts.
Panel may well be reading high, try putting something over the solar panel and see what happens.
I’ve just pulled up and checked everything was off and also unplugged the TV as sat on standby will be a tiny draw and it’s now showing 2.1amp
Edit.
Settlement to 1.4amp draw.
I tried the water pump to add load and it spiked to 3.5amps then settled back to 1.4 with nothing on
Update update 🤦🏻‍♂️
Aldi system was on.
We now a draw of 0,5amps with 12.7v showing
Yup 🤦🏻‍♂️
Edit.
Update update 🤦🏻‍♂️
Aldi system was on.
Yup 🤦🏻‍♂️
You don’t have an inverter on standby do you?
Have you calibrated the display?
Edit.
Update update 🤦🏻‍♂️
Aldi system was on.
Yup 🤦🏻‍♂️
If Aldi is a problem, try Lidl, other budget supermarkets are available :rofl:
My Seattle panel shows a almost 0.5 Amp draw just to run the panel itself. The Alde panel draws about the same. One thing to consider is if you have a heater to stop the waste tank freezing. The switch for mine is a little round rocker switch down low to the floor by the consumer unit. Easy to knock on by accident as you walk past. Stupid place to put it. There is also another rocker switch to turn on the fan to blow hot Alde air into the cab section. Stupid place to put that too. Then again you may not have them anyway.
Yup got both of those... In fact 2 fans to blow air. And they do seem to pull a lot of amps for such a little device.
Ive seen the ice heater thing. Not tried it yet as not read any info on exactly what it does reheating etc. Might be worth a look this week though with the cold snap we are having.
My radio flattened a pair of 110amp leisure battery's as it was drawing 2amps on standby, after a lot of help from the knowledgeable funsters I investigated and found a kill switch had been fitted hidden on the dashboard.
