220/12volts
tankerpaul50
spain
i'm a newbie
Good Morning all i need some help again i have an electrical promblem my 12v systwm as stopped working but if i plug my 220 in thwn everything is working fine any ideas what could be the problem i have a 2009 Burstner t700
Yep as above. Unplug the mains and test the battery at the terminals with a multimeter.
Update: check the battery fuse also.
But not right away. Leave it 30 mins before testing but I suspect if it's that flat that nothing works you may get a poor reading right away.
Could also be a fuse. There should be a main fuse on the + wire from the leisure battery to the 12V distribution unit, usually very close to the battery.
The big 50 amp fuse next to the leisure batteries popped on my T680 for no apparent reason, replaced it and it's been fine ever since. 🤷‍♂️
Thank you all i have now found the fault a loose wire on the negative teminal
