is it possible to fit 2 x 11kg gaslow cylinders in the standard Autotrail Apache 652 gas locker.
Juggler
Juggler
We had them in our old AutoTrail Delaware.
If all the AutoTrail lockers are the same the answer must be Yes.
Richard.
My 700 can certainly take 2 large bottles..
Steve, I've just checked the 700's spec and it's also down as 1 x 7kg and 1 x 13kg in the brochure.
......so based on your observations a 2 x 11kg combo must fit a 632![]()
The AT tech specs are indicating that the Frontier range (Delaware, Scout, Commanche) all have a bigger locker capability than the OPs Apache range van.
Our starter van was an Autotrail and if I recall correctly the gas cupboard would not accept two larger bottles.
Steve has a 634 so he'll know the answer (I hope).
See my response belowis it possible to fit 2 x 11kg gaslow cylinders in the standard Autotrail Apache 652 gas locker.
Juggler
Just noticed others quoting Apache 632. If that is what you have then it has the exact same locker as my 634, almost bought the 632 so had a good look over itis it possible to fit 2 x 11kg gaslow cylinders in the standard Autotrail Apache 652 gas locker.
Juggler
Just went out and measured my gas locker
dims:- 24” wide x 12-3/4” deep x 26” high. I have 2 x 6kg bottles which, when moved as far apart as I can get them, leaves a 4-1/2” gap. Online dims for the 11kg is 304mm or 1/32” shy of 12”. If correct, then there will be a 1/16” gap between the bottles. Given that the depth is greater than the bottle diameter, you will have an overlap so, I believe I could get them in my locker quite easily. I think my Imala had the same size of locker but in a different location. I would measure 2 x 12” circles on a piece of card then use these to check. Good luck
@Juggler Did you get the second one installed?Sounds like that there is a good chance that they will fit (just). Already got one installed so I will ask supplier to try second in place, just to be sure.
Thanks for all help
Juggler
