- Jan 23, 2023
- 273
- 273
- Burstner Travel Van
- Newbie - bought first MH 11/03/2023
Would not do it…… because?Theoretically yes the maths is about right, would I do it ? no chance![]()
You’d have flat batteries, risk the BMS shutting down and ‘could’ have issues re charging themWould not do it…… because?
2 x 100Ah LiFePO4 - using 2400w = a possible 55 minutes?
Using an online calculator I arrived at this figure.
Would anyone with real world expertise say this number is in the right ballpark?
PS: Victron batteries via Victron 3000w inverter.
No, don’t have the batteries yet - that BMS info sounds very usefuli assume you dont have the batteries yet? the reason i ask is that because the bms on my battery actually provides that information whenever i am drawing current - it tells me how long i can draw current for at the rate i am using it at. i assume it will turn itself off when it reaches a certain point, but what i dont know is whether that time is the time shown on the bms or whether it will shut off before that time as a safety function.
Hi Jon - I wouldn’t need to run anything that long - prob 15 to 20 minutes max most of the time. The maximum possible run time that could be needed is 30 minutes, but that’s unlikely ever to happen.Why would you want to run 2400w for 55 minutes? Usually the highest draws are things like hair driers, 5 minutes?
Might you be better off considering something with lower draw like a remoska or microwave?Hi Jon - I wouldn’t need to run anything that long - prob 15 to 20 minutes max most of the time. The maximum possible run time that could be needed is 30 minutes, but that’s unlikely ever to happen.
Situation is - friend has bought a Ninja Foodi 8 mini oven and it’s an excellent device - but draws 2400w against the 1700w for the air fryer I’ve been considering.
at 2400W, note that you will be running the Victron "3000W" Inverter at 100% power output, which is maybe not a good idea?Hi Jon - I wouldn’t need to run anything that long - prob 15 to 20 minutes max most of the time. The maximum possible run time that could be needed is 30 minutes, but that’s unlikely ever to happen.
I’ve ordered a Remoska and been considering a 1700w Ninja air fryer.Might you be better off considering something with lower draw like a remoska or microwave?
I think one of you re earlier threads mentioned solar, this could change all of your calculations, we ve been in the situation where our solar was almost keeping up with the small remoska although not in UK.
One other point .... have you got the Battery Specs? very often a 100Ah battery will have a maximum current output of 100A. So a pair will be 200A (if perfectly balanced).2 x 100Ah LiFePO4 - using 2400w = a possible 55 minutes?
My 6m Burstner Travel Van only has room for 3 x 100w solar panels, but my long trips are going to be be mostly Southern Europe, North Africa, Turkey - so hoping they will be adequate.Once you have used the air fryer for 30 mins ,that's your batteries down to 50% approx.
Have you got the ability to recharge that loss back, solar wise or b2b.?
could you add a folding solar panel to your 'armoury'? though i think increasing your battery capacity is key to it all if youve gone as far as you can with putting the power back into the batteries ?My 6m Burstner Travel Van only has room for 3 x 100w solar panels, but my long trips are going to be be mostly Southern Europe, North Africa, Turkey - so hoping they will be adequate.
B2B also being fitted, so could do an emergency top up in evening if necessary?
Buy a generator or go on sites, or get a different van, or, have a bigger inverter and twice as many lithium batteriesI’ve ordered a Remoska and been considering a 1700w Ninja air fryer.
I oven cook a lot at home, so the Remoska should cover that - thinking the air fryer would be good for smaller and quick cook items.
But suffered a case of “oven envy” when I checked out my friends Ninja Foodi 8![]()
Loads of choices to do what you want to do, but not with the set up you described
Good advice Eddie. My next van is likely to be all electric leisure side but heating will be diesel and the available power needs to be used smartly. It is no substitute for mains supply if a ninja or similar is going to be usedBuy a generator or go on sites, or get a different van, or, have a bigger inverter and twice as many lithium batteries
Output from the batteries reduce considerably as they get towards empty, so I don't think you'll sustain that current draw.2 x 100Ah LiFePO4 - using 2400w = a possible 55 minutes?
For LiFePO4 cells you can safely ignore Peukert as it is in the weeds and other variables completely swamp this.You should not ignore the Peukerts Exponent.
I used 1.05 but even at this value it knocks nearly 10 minutes off the calculation.For LiFePO4 cells you can safely ignore Peukert as it is in the weeds and other variables completely swamp this.
I seem to recall for most LiFePO4 cells I look at it was stupidly low at around 1.02 or so. Not sure where you got 1.1 at the high end from?
Victron for example from what I have seen recommend 1.05 to be on the safe side. I have not seen anyone suggest a higher value than this though.
