Aerialmark
Hi, as the title suggests I'm having problems with my 12v supply. Ive narrowed it down to the fuse board which is definitely faulty.
The fuse-board is a Calira VB-05 and my motorhome is a 2008 Weinsburg/Knaus Imperallie.What has happened is the green relay has burned (I could smell it ) and is not switching over to switch on the 12v supply when the main switch on the panel is turned on. If I manually switch it over by flicking the little green tab on the top of the relay it works ok but will not switch from the panel even though everything else comes on and works ok. Also if I put the fuse in nearest to the green relay and manually flick the relay this causes it to burn as I think its tracked over and damaged that too.
My question is as I see it I have 2 options either find a replacement fuse board ( Calira VB-05 ) or replace the whole lot ( fuse-board , charger and control panel ) as they all talk to each other with maybe a newer system. Can this be done and could you suggest somewhere that could possibly fix the existing or supply new equipment ? Thankyou.
