12v socket, Fridge, and Sat Dish no power!
cantonalegod
Devon
Rapido 8086df
Hymer Exsis i414 A class
We had failure of both 12v outlets, due to a dodgy two way cig lighter plug in. One in the Fiat part, and on in the Habitation.
We found a blown 15amp fuse in the engine compartment fusebox, so replaced that and the 12v cig lighter socket in the cab is working again.
Not having as much luck with the Hab area.
We found another 15a fuse behind the removable back panel under the drivers seat which was also blown, we hoped this would solve the problem, but no! (Don't have a clue what that one did).
Basically the 12v cigarette lighter, and the 12v ignition live from the battery to the fridge, (which also powers the Sat Dish), have no power. They are all on the same side and fed power together.
The Sat guy linked into the fridge feed to fit the dish, i spoke to him to see if he had added an additional fuse, he said no. It was all fitted over 5 years ago.
We have checked every fuse we can find on the vehicle, (well over 50), 2 fuse boxes next to each other in the engine bay, a fuse box low on the dash to the right of the steering wheel, all the fuses on the EBL 130 under the passenger seat, fuses on the adapter under the driver seat, additionals, as mentioned, at back of the drivers seat. Also checked a 50a and 20a by the engine battery, an in-line 20a between the leisure batteries, and 2 on the back of the Sat control box.
Fuses everywhere!
Display panel on fridge still works, but no switch to 12v.
Permanently live are the electric step, one set of interior lights, and the outside awning light, all working.
Everything else is working.
Anyone got any more ideas?
I'll post in questions as well if that's OK.
SORRY, LOOKS LIKE POSTED TWICE IN THE SAME PLACE, AND CAN'T DELETE
