It's now beyond my understanding. We had no problems with LB 12v until a few days ago, symptoms are:
Could it be a knackered Sargent charger/psu?
Could it be knackered LBs (They are not that old and have performed well so far)?
- LBs seemingly not charging on alternator
- LBs seemingly 100% having been on EHU
- LBs take a charge from the Victron Solar unit
- Unhook and drive for a couple of hours to next site
- Set up and switch on 12v, all seems fine
- After an hour or so voltage drops to 11ish
- Then the Sargent 480 starts to report low voltage everywhere including starter battery
- Water pump will come on at 10v and run constantly (it's fine at 12v and on EHU)
- Starter battery is healthy and does charge from alternator but Sargent reports as low as 3v
- Turn the master switch of the Sargent PSU off for 20mins, then on again and it seems ok for 5mins before going back to reporting low voltage everywhere
- LBs are actually about 11v with a multimeter, starter is fine
- No significant drain reported at the control panel and everything unplugable is unplugged
- All fuses that I can locate are good
