- May 5, 2022
- 2,024
- 14,610
- Hymer B778 PL
- Since 1992
Hello fellow Funsters.
I have read quite a bit about off grid power (we do rallies in fields) and before converting to a motorhome I would have a couple of 110 ah batteries in the caravan with a solar panel. In those days lead acid with factory fitted charging systems. All would be fine until this time of year with shorter day time and less sun to give any meaningful charge. I found that the batteries would last about 3 years. Main power drain being television, lighting, water pump and gadget charging.
Move on now to our motorhome. We have a 2017 Hymer with 2 110 ah Varta sealed lead acid batteries. When we are not on EHU after watching television for a couple of hours on Friday the voltage is down to 13 volts. By Sunday 12.5 volt. I am looking to replace the batteries next year after we return from Spain and the sun drops below the yard arm, but what with?
I am 68 in January and I will have to apply for my C1 in 2 years. There should be no reason not to get it, but you never know. Spending north of a grand on Lithium batteries does not add up as you rarely recover money spent on accessories. Lead acid are a direct swap but I have read a bit about AGM which seem to be a step up? If I fitted 2 AGM batteries will the factory fitted 12 volt charging system work with them? There are also solar panels but I assume they plumb into the moho electronics.
Any thoughts in simple terms would very much be appreciated.
