Hi all
I have a strange problem with my 12v electrics after replacing the leisure battery. I have an old 2005 hymer with an electrobloc EBL 101 and DT201 control panel.
After turning off the battery cut off switch on the EBL and replacing the battery and then turning it all back on again the DT201 has come back to life, so nothing wrong with the EBL battery cut off switch or the fuses, but I have no other 12v electrics.
I've looked at the EBL circuit diagram (I'm no expert) and it seems that everything on the 'pre control panel side' (told you) is working including the charger and the power supply to the control panel but everything that the control panel should switch on is not. Oddly, this includes the fridge and step which do need the control panel to be turned on before they will start working after the cut off switch has been flicked.
I've followed the start up procedure to the letter including resetting the battery capacity, etc.
Schaudt have been no help . Apuljack have not yet got back to me.
Sorry this is a lot to throw at you and this is my first post (3 years of happy motorhoming before finally hitting the thing I can't fix) but I thought it might be worth putting a post out in case anyone knows anything or has a good suggestion?
Here's hoping...
Here's hoping...
