- Apr 6, 2019
- 4,564
- 9,051
- RV
- FourWinds Windsport 6.8L V10
I tried the RVOC forum but not many responses.
I have air assist bags x4 on my RV. Either the pump or solenoids are not working properly. Air-Lift Model 16130
I was trying to inflate all four corners a little - the system has two toggle switches and double gauges. Toggle 1 press left for rear left, press right for right rear etc...
It still works on 2 of the bags but does nothing on the other two. Fuse blew too!
I suspect the pump may be failing? But I guess it could be the solenoids too - seen in the "spaghetti" picture below.
Is there a simple test to see if the solenoids are faulty? I have a spare 12V battery and wires available and so could in theory supply power to each one individually?
Looking for advice as the pump is £180 plus shipping (approx) and Air-Lift closed down July 2022!
If I can confirm the solenoids are okay then I think I can replace the pump unit with a UK sourced 12V, rated to 130+psi bu getting appropriate adaptors? The old pump is in a picture below and has a "push small black plastic pipe inside" style connection which you simply depress the little collar to release the pipe again - very similar to some speed fit / push fit plumbingsystems.
