I'm a little confused hence asking here, possibly again, apologies.
I'm about to do some checking over and as necessary, preventative maintenance on my 12v systems, in readiness for replacing the old Lead 12v 100AH leisure battery with a new-to-me 12v 200AH AGM - it will require new main battery feed wires to the Sargent unit I know as the factory fit are really skinny.
So, while I'm at it, I'd like to install an inline volt/amp meter display; something that can clearly, relatively accurately, and constantly show me the draw/drain from the leisure battery. I do have the Sargent EC480 control panel and will be sure to recalibrate it; it, of course, shows this information once the right buttons are prodded and, I guess, gets the info from the Sargent EC500 PSU.
Anyway, this appeals, but will it be right for the job, or do I need something beefier or less beefier even? Is there an alternate recommendation (safe but cheap).
I understand this particular unit won't show "charge" out of the box (unless I wire it up backwards!?) but my concern right now is having an in-my-face view of the drain on the battery, safely and for not much money.
Also... what would be an average drain in shutdown mode, perhaps 500mA...?
Thanks!
Thanks!
