It’s similar the only thing that lights up is the 240 volt bulbDoes your control panel look like this? if so is the 3 way switch on the left hand side in the down position for the leisure battery powering the habitation area and the far right hand switch on?
found that switch and tried on and off no change is there anything to suggest unit is on as no lights I can seeWhat was the voltage on the 12v side before plugging into mains?
If too low the Elektroblock will have shut the system down, there is a switch on the front of the Elektroblock you will have to turn off and then back on. May not work on a van of that age those switches are well known for being dodgy.
