Hi, we have a bailey autograph 2018 motorhome. When plugged into EHU the 12 volt system should work through the mains but it is draining the starter battery.
Message comes up on tv saying powering down due to low voltage, by this stage the starter battery is flat and we have to jump start it.
If left the lights go out and nothing 12 volt will work yet the leisure batteries are fully charged.
We have new leisure batteries and a new starter battery. If not plugged into EHU 12 volt system seems to run from leisure batteries ok.
I have checked the leisure batteries are charging on the seattle panel and it seems to be working as voltage shows an increase.
Rang bailey and there advice is to fit an inverter! Please has anyone else had this problem and what is the cure, took it to the dealers and was told they had no idea.
