If it's a nylon insert don't use WD40 as it makes nylon swell.The hinge has a plastic insert which somehow swells and eventually seizes solid twisting the door edge and/or frame.
Chances are it was pressed in and an interference fit in either the larger section or the smaller bottom section.Hi again, just tried injecting Plusgas penetrating oil into hinge, and maybe it’s working a bit. Following up with high viscosity oil dribbled over top of hinge.
Does anyone know how to extract the top pin on the hinge?
Looked like it was a hex-drive but not so.
Don’t know cross section of hinge so not sure how to approach removal etc
Regards
